Author Topic: secondary clutch coupler fix??  (Read 14982 times)
heiner921
« on: November 09, 2014, 08:15:24 PM »
Any way to fix these broken coupler buttons?
Re: secondary clutch coupler fix??
« Reply #1 on: November 10, 2014, 07:14:44 AM »
Considering the work that these drives do would it be better just to replace it?  I probably have a few spares if you need one.
« Reply #2 on: November 10, 2014, 08:48:55 AM »
thats the original style,80 and up are much better.
heiner921
« Reply #3 on: November 10, 2014, 09:12:21 AM »
I do have a newer style clutch that came in a parts bin.... not sure if the clutch is any good.    Any one have spare couplers?
« Reply #4 on: November 11, 2014, 08:26:29 AM »
couplers should interchange
heiner921
« Reply #5 on: November 11, 2014, 09:11:17 AM »
I have 2 old style clutches and 1 newer style clutch.... Both old style clutches have broken buttons. .. I'll replace the coupler on the 1 with new style but I will still need another coupler because I have 2 sleds
« Reply #6 on: November 11, 2014, 05:29:22 PM »
complete clutch will interchage also.check the bushing in the inner sleeve that rides on the jackshaft, when these wear out it lets the clutch wobble on the jackshaft which can ruin couplers. if troy cant help with a coupler i can.
heiner921
« Reply #7 on: November 17, 2014, 08:47:18 PM »
anyone know where I can get those bushings that ride the jack shaft?
« Reply #8 on: November 18, 2014, 06:38:44 AM »
The bushings you are speaking of have a fair amount of play even when "new"...   I've already run into this...   Kawhead might have new bushings?  I don't have any...    I get split bushings made through my machinist with a tighter tolerance. Even though the bushings are designed to wear faster than the shaft itself, there is always a little shaft wear over 30+ years of use which is why even new bushings aren't a perfect fit. Obviously better than the old, worn ones though.  Check ebay if you can't find any through here.
« Reply #9 on: November 18, 2014, 08:27:46 AM »
i'll check on a bushing.....check that area of the shaft for taper,a new bushing wont help much if its worn
heiner921
« Reply #10 on: November 18, 2014, 09:02:46 AM »
I have a clutch with a good bushing that fits good (no excessive movement) but I still need one for another clutch. The jack shaft is good
« Reply #11 on: November 19, 2014, 08:34:02 AM »
i have one left that i'd need as soon as i sold it.....
heiner921
« Reply #12 on: November 19, 2014, 09:12:36 AM »
Is all good. The are on ebay.... I am looking for a clutch alignment tool.. I messaged interceptor 398 but haven't had a response
