Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
KawasakiTrax Community
Tech Information
General Help
Finally got the restore project running. bogging issue
« previous
next »
Print
Pages:
1
2
3
Author
Topic: Finally got the restore project running. bogging issue (Read 33956 times)
Hero Member
Re: Finally got the restore project running. bogging issue
Reply #15 on:
November 30, 2014, 08:36:37 AM »
one more thing popped into my feeble, Neanderthal brain. A big mouse nest in the exhaust pipe might act this way...kinda a long shot, but you should be able to feel a pretty unrestricted flow of exhaust gas from the pipe, even at idle.
Logged
heiner921
Jr. Member
Reply #16 on:
November 30, 2014, 01:12:44 PM »
I'll have to observe close when I mess with it next. Been running it without a belt currently.
Logged
Hero Member
Reply #17 on:
December 01, 2014, 12:14:16 PM »
if the fuel bowl levels look ok try choking one carb at a time;one cyl lean or both....if it idles do the same;are both cyls 'pulling their weight' and a new set of plugs 1st thing...
Logged
heiner921
Jr. Member
Reply #18 on:
December 01, 2014, 03:46:30 PM »
Put new plugs in... didn't help... cant get it to even start now.... had a buddy of mine take then to the skidoo dealer he works at... He was gonna boil the carbs in soapy water so they are like brand new
Logged
heiner921
Jr. Member
Reply #19 on:
December 07, 2014, 09:54:28 AM »
Ran a compression test. 140 on mag side and about 133 on pto side. Held the pressure for over a minute. Took 4 pulls to reach these pressures as well
Logged
Hero Member
Reply #20 on:
December 07, 2014, 01:08:18 PM »
remember, Intruder carbs are different (jetting) on mag/PTO sides Idle should be set at 3,000.. A worn belt can also cause bogging, as well as carbs being unbalanced
Logged
Full Member
Reply #21 on:
December 07, 2014, 05:36:46 PM »
Put in new plugs and cannot get it to start now. Sounds like ignition system, sounds like fuel delivery, is not compression problem.
Luke check the ignition system. You have great compression. Check the ignition system.
Do you have spark?
Hang in there.
Logged
heiner921
Jr. Member
Reply #22 on:
December 07, 2014, 10:07:32 PM »
Got it running after getting carbs back from cleaning... takes a few pulls to get running. Idles well but still has low end bog. Doesn't die at all. Bog clears out through midrange and at WOT. New plugs in.. belt removed while running on a stand off the ground
Logged
heiner921
Jr. Member
Reply #23 on:
December 09, 2014, 04:49:26 PM »
Any other ideas on the low end bog? Through Mid range to wot it clears out nicely
Logged
Hero Member
Reply #24 on:
December 09, 2014, 05:02:52 PM »
Did you check/adjust your air screw position (like I suggested?) Also, try raising the clip position on your needles "one position" (lean) and see if this helps...
Logged
Website: torysvintagesleds.com
5kaws
Full Member
Reply #25 on:
December 09, 2014, 05:04:03 PM »
Kind of oil you using ?
And mixing it at?
Logged
heiner921
Jr. Member
Reply #26 on:
December 09, 2014, 07:07:17 PM »
I'm using blue marble oil. Not mixing oil in gas but I did put a small amount down cylinder as I was bleeding oil injection system sled has had long running time since then.. I tried adjusting those air screws as u said and never heard idle change when I was to 3 full turns out. Put back to 1 and 1/2 turns out. Will try other suggestions tomorrow
Last Edit: December 09, 2014, 07:10:00 PM by heiner921
Logged
BornagianKawi
Full Member
Reply #27 on:
December 09, 2014, 07:40:06 PM »
Just did 81 Intruder, sounds like same problem. But I had no headlight or taillight. Chased it back to ground wire. Put ground wire from taillight to tunnel. All problems went away. Including bogging issue. Ignition troubleshooting, loose ground connection will cause intermittent spark. And other problems. My 2 cents. Good luck.
Logged
heiner921
Jr. Member
Reply #28 on:
December 10, 2014, 07:07:49 AM »
I don't have a spark issue. I have an in line tester that lights up. Works really well. All my lights work as well. But I will move my ground and see what happens
Logged
Administrator
Hero Member
Reply #29 on:
December 10, 2014, 07:39:11 AM »
Does this sled still have the enricher hooked up, they can suck air and cause problems. Did the gas tank get cleaned and are there no kinks in the gas line??
Logged
Print
Pages:
1
2
3
« previous
next »
Tech Information
General Help
