Author Topic: Parts interchange  (Read 73448 times)
Parts interchange
« on: October 15, 2012, 03:52:19 PM »
    Parts Interchange
I know somebody was asking about part number interchange in another thread so I thought I'd start a thread on it. If you know of any other part numbers that interchange between Kawi/Cat/and JD please add to the list.
Center Seal O Rings: Kawasaki pn# 92055-3002, Arctic Cat pn# 3001-437
32mm Carb Flange: Kawasaki pn# 16065-3008, Arctic Cat pn# 0115-544
36mm Carb Flange: Kawasaki pn# 16065-3007, Arctic Cat pn# 0670-197
Chain Tensioner Pads: Kawasaki pn# 12053-3501, Arctic Cat pn# 0170-228
Econo Carb Needle Jet Retainer: Kawasaki pn# 16065-008, Arctic Cat pn# 6505-044
Carb O ring: Kawasaki pn # 92055-044, Arctic Cat pn# 6505-042, John Deere pn# R34812 (supposedly cheaper than Cat), McMaster-Carr pn# 9464k12 $4.62 for pack of 100
While not Kawi/Cat/JD these are other parts that interchange with Kawasaki:
Oil system Banjo: Same as Banjo for the 86 Polaris Indy 400. Polaris Part # 3083894
Renumbered Kawasaki Parts that are still available from a dealer:
Pin 6.5x10x38 old pn# 920243-3001, new pn# 92043-1370
Bushing 40x44x12 old pn# 92028-3008, new pn# 92028-1511
Spacer 10x16x.8 old pn# 92026-3001, new pn# 92026-1304
Nut, special lock 6mm pn# 92019-008, still available under same part number
Roller old pn# 92122-3001, new pn# 92122-1152
Washer, spider old pn# 92022-3016, new pn# 92022-1899
Bolt, flanged 6x20 old pn# 92001-3001, new pn# 92150-1014
Bushing 32x36x20 old pn# 92028-3005, new pn# 92028-1513
Bushing 25x28x30 old pn# 92028-3004, new pn# 92028-1514
Bushing 50x55x20 old pn# 92028-3006, new pn# 92028-1512
Washer Split old pn# 92022-3001, new pn# 92022-1897
Washer, special conical old pn# 92022-3015, new pn# 92022-1901
Guide, Wear (plastic clutch guides 79-82) old pn# 13070-3002 new pn# 13070-1185
Red and Amber Side Reflectors Stratolite 3-1/8" x 1-1/2" Black ABS bezel #99BZ
http://www.stratolite.com/mcart/index.cgi?code=3&cat=2
Added some more numbers today. Found out some of the drive and driven clutch parts are still available and are used on ATV clutches..
Kawi PN:16065-3010
carb flanges from mikuni (genuine) for invader 440
PN: vm38200
also 074701 kimpex or lemans
Kawi PN:16065-3008
invader 340, 78-79 intruder, intriguer, drifter340-440
PN: vm32205
also 071013 kimpex or lemans
Kawi PN:54005-3502
fits all brake cable
PN: 0513839 kimpex
Go to the top of the pageReport Post
Intruder
Starter brushes for the Hitachi S108-34 starter, available from Arctic Cat.
AC 0145-071 Positive brush
AC 0145-072 Negative brush
Link to the AC parts diagram
http://www.brownsleisureworld.com/link.cgi...STARTMOTOR.html
Replacement Kawasaki Primary clutch ramp bushings. www.mcmaster.com part number: 6679K15
"WARNING: THIS IS A HIGH PERFORMANCE SNOWMOBILE AND SHOULD NOT BE OPERATED BY A NOVICE OR INEXPERIENCED OPERATOR."
Invader 440
Interceptor
Added a carb o ring part number for John Deere. Suppose to be cheap dollar wise.
Added the new Kawasaki part number for the 79-82 plastic clutch wear guides.
 KAWISnCATS
The oil check valve gaskets used on 81-82 LTDs and Interceptors, P/N: 11009-3028, are still available through your local Kawi dealership...
Habbeli
QUOTE (KAWISnCATS @ Dec 20 2008, 02:07 PM) *
Which ATV?
QUOTE (Habbeli @ Jan 22 2012, 04:37 PM) *
Which ATV?
The following mules:
KAF540- C1, D1, E1
KAF620- A1, A2, A3, A4, A5
KAF620- B1, B2, B3, B4
« Last Edit: April 22, 2019, 07:20:54 AM by Interceptor398 »
Habbeli
Re: Parts interchange
« Reply #1 on: December 02, 2012, 11:33:48 AM »
What is the difference between
49048-1054 and 49048-1057?
« Reply #2 on: January 26, 2013, 11:24:54 AM »
This should come in handy for you guys! parts interchange for Kawasaki and John Deere part numbers
Habbeli
« Reply #3 on: November 17, 2013, 01:51:47 PM »
Is there any difference at all  ???
« Reply #4 on: November 22, 2013, 07:06:31 PM »
Not sure on that since i havent seen them myself
Habbeli
« Reply #5 on: November 26, 2013, 08:37:35 AM »
Okay  :-[
« Reply #6 on: January 16, 2014, 08:41:43 AM »
On the 4/6 engine the pulsar coil & the exciter coil cross reference to a 1989 Kawasaki 550 jet ski (stand up model) the other is a Arctic Cat 1974 el tiger 440 T7 Kawasaki engine sorry I don't have the part numbers
Invader440
    • Curt's Snowmobiling Page
« Reply #7 on: January 04, 2015, 10:01:01 PM »
Arctic Cat tensioner pad should be  pn# 0107-228 vs 0170-228
« Reply #8 on: January 17, 2015, 06:53:09 PM »
For 550 owners:
Should you have a failure in the magneto system, the mag system from the 440 Invader will work provided the entire system is replaced. Flywheel, mag coils, etc.
I had to resort to this when I discovered that the previous owner had sat the flywheel on his bench and the magnets collected some small nuts & screws. When he installed the flywheel and started the engine all the"stuff" tore up the coils and broke the magnets off the flywheel (the magnets on 550's are glued to the flywheel instead of being recessed).
« Reply #9 on: January 27, 2016, 04:28:41 PM »
Invader crank seals
Seal Numbers from Dennis Kirk:
Oil Cover Seal - #260676
2-piece PTO side seal - #1486
Mag side seal - #14205
« Last Edit: January 28, 2016, 02:49:37 PM by Interceptor398 »
« Reply #10 on: January 14, 2019, 12:55:50 PM »
Sproket:
Thank heavens you just resolved my issue.
Kawasaki Exciter coil
21049-3001 regular invader 440
21049-3007 4/6 or 89 jet ski 550
Kawasaki Pulser coil
59026-3002 Regular invader
59026-3008 4/6 or 89 jet ski 550
A regular invader stator for the invader will not work in the 4/6...
« Reply #11 on: September 08, 2021, 02:33:44 PM »
The Kimpex 04-269 rear gas shock has been discontinued, however the SPI SU-04282 shows it fits the same model SKIDOOs as the Kimpex part did, so it should work on the Kaws as well.
« Reply #12 on: February 15, 2022, 09:52:20 AM »
Chain Tensioner Pads: Kawasaki pn# 12053-3501, Arctic Cat pn# 0170-228 or 0107-411
All Balls PN:  14-2001
« Reply #13 on: February 15, 2022, 10:37:23 PM »
Great info!
« Reply #14 on: August 11, 2024, 08:32:45 PM »
Replacement seals for the Invader oil pump:
Honda Part Number
Large seal:  91201-965-000
Small Seal:  91201-HA0-004
