Author Topic: 79 Invader  (Read 15225 times)
Fry199
79 Invader
« on: January 18, 2015, 02:35:33 PM »
Does anyone live in ohio or near ohio? Im having a hard time get my invader tuned in I put carb kit in did crank seals it deffinetly helped but not 100% yet some times it starts up and runs great others its real boggy and wont idle I ohmed the stator its right on specs. any help would be appreciated. If you live near ohio maybe we could get together on a weekend and tune this in?
Re: 79 Invader
« Reply #1 on: January 18, 2015, 04:02:47 PM »
I don't live in Ohio, but have a couple of questions.  First, how clean are the carbs and the jets?  The second question is whether or not the primer may be leaking?
Fry199
Re: 79 Invader
« Reply #2 on: January 18, 2015, 04:22:24 PM »
Crabs are spotless cleaned them at least 15 times trying to figure this out I have new jets on the way pilots are chewed up from being taken in and out so many times the tank is spotless fuel pump is clean the filter in the tank Is clean I even added filters on the fuel lines from the pump to the carb. I cant get it to run half way decent both cylinders get hot when I pull one plug wire off in kinda spits and sputters I pull the other off it dies out. I know the primer t has a leak when I prime it the t squirts fuel.
5kaws
Re: 79 Invader
« Reply #3 on: January 18, 2015, 05:13:33 PM »
I live in Ohio.  20 min south of cleveland.
                               -mike
Fry199
Re: 79 Invader
« Reply #4 on: January 18, 2015, 05:21:59 PM »
5kaws could you please email me josh_199@hotmail.com I'm at a lost cause with this thing
5kaws
Re: 79 Invader
« Reply #5 on: January 18, 2015, 07:21:44 PM »
I sent you an email
-mike
Re: 79 Invader
« Reply #6 on: January 19, 2015, 07:26:16 AM »
Check the gas line in the tank.
Re: 79 Invader
« Reply #7 on: January 19, 2015, 08:25:02 AM »
unhook that primer first off....the cyl that doesn't stall the motor is at fault, pto or mag?
Fry199
Re: 79 Invader
« Reply #8 on: January 19, 2015, 11:49:28 AM »
Pto
Fry199
Re: 79 Invader
« Reply #9 on: January 19, 2015, 01:39:52 PM »
Now it seems to be okay when I pull a plug wire off it dies out just as much as the other my temps on the cylinders are about the same plugs look good it idled fine I am running some premix in there with the oil imjection hooked up as well because I just did crank seals and didn't want it running on dry gas while I bled the oil system
Re: 79 Invader
« Reply #10 on: January 20, 2015, 10:18:31 AM »
sounds like it needs to be run a little to clear out.
