Author Topic: Primary clutch slides And bushing  (Read 19073 times)
5kaws
« on: January 22, 2015, 12:58:37 PM »
Hi folks
Title says it all. I'm looking for 3-6 white plastic slides for the invader primary. And the one  bushing on the bottom side of the clutch.   My one invader has 5500 miles on the original clutch and when I gave it a once over noticed the slides are wore at an angle and the bushing is sloppy.    Thought I found the parts from a kawasaki mule , but slides are discontinued and the bushing I'm looking for is bigger.  So anyone have any? Or ideas? I'd appreciate it    Thanks -mike
5kaws
Re: Primary clutch slides And bushing
« Reply #1 on: January 22, 2015, 01:11:42 PM »
This is the bushing to avoud confusion
« Reply #2 on: January 22, 2015, 01:44:00 PM »
Some of the clutch parts are still available from your local Kawasaki dealer.  I'm not sure about that specific bushing (I don't have my parts manual near by to look it up), but looks like those plastic sliders are re-numbered and still available.  Here's some info from the parts interchange thread:
Renumbered Kawasaki Parts that are still available from a dealer:
Pin 6.5x10x38 old pn# 920243-3001, new pn# 92043-1370
Bushing 40x44x12 old pn# 92028-3008, new pn# 92028-1511
Spacer 10x16x.8 old pn# 92026-3001, new pn# 92026-1304
Nut, special lock 6mm pn# 92019-008, still available under same part number
Roller old pn# 92122-3001, new pn# 92122-1152
Washer, spider old pn# 92022-3016, new pn# 92022-1899
Bolt, flanged 6x20 old pn# 92001-3001, new pn# 92150-1014
Bushing 32x36x20 old pn# 92028-3005, new pn# 92028-1513
Bushing 25x28x30 old pn# 92028-3004, new pn# 92028-1514
Bushing 50x55x20 old pn# 92028-3006, new pn# 92028-1512
Washer Split old pn# 92022-3001, new pn# 92022-1897
Washer, special conical old pn# 92022-3015, new pn# 92022-1901
Guide, Wear (plastic clutch guides 79-82) old pn# 13070-3002 new pn# 13070-1185
5kaws
« Reply #3 on: January 22, 2015, 01:48:30 PM »
Thank you so much!
I tried looking for something on here, but had no luck on it.
Might have been had wrong info in the search.
I will do some more reserch soon here.  Thanks buddy.  -mike
« Reply #4 on: January 22, 2015, 01:51:18 PM »
You're welcome.   :)  The parts interchange thread is located here:  http://kawasakitrax.com/kawiforum/index.php?topic=11.0
It has been VERY helpful over the years.
5kaws
« Reply #5 on: January 22, 2015, 01:58:26 PM »
Right!! Everything on this site has been!!
I need to get the kaw books with the part numbers in it.  I have factory manuals , which books have the numbers ?
5kaws
« Reply #6 on: January 22, 2015, 03:24:33 PM »
The part number for the slides is what I Tried to order and they said its been discontinued.   The slides are the same as the kaw mule.  I can't see there not being none available.   ?
Pmlecom1
  • The Blue Demon
« Reply #7 on: January 23, 2015, 04:49:18 AM »
When I rebuild my clutch, I brought the assembly to a local machine shop.  The owner used to race sleds.  He had some rough material and just made a bushing to fit the part.  He dressed up the mating surface so all would be nice nice when things start turning.  My Kawa dealer wanted a specific bike model to order those slides.  So I found a 1998 Kawa Prairie also has that same clutch.  He was able to order the parts I needed.   :D
5kaws
« Reply #8 on: January 29, 2015, 10:45:59 PM »
What's this part number and size? Thanks
Pmlecom1
  • The Blue Demon
« Reply #9 on: January 30, 2015, 07:26:51 AM »
Bushing part number 92028-3001   it is 40 x 44 x 20 mm
5kaws
« Reply #11 on: January 30, 2015, 12:09:28 PM »
Perfect!!
Thanks guys !!
5kaws
« Reply #12 on: February 06, 2015, 06:20:14 PM »
Rebuilt my invader clutch to like new condition for under 45$ All new bushings ,slides ,ramp bushings. Like I say like new, no more noise or broken sounds lol.
Thanks again guys!!!  Mike
