Author Topic: Airbox versus Pods on 1979 Invader  (Read 13806 times)
rickbmac
« on: February 11, 2018, 06:57:47 AM »
Morning all,
I have read that use of airbox is suggested on 440 due to EconoJet Carbs.
What are thoughts/suggestions of running pods rather than Airbox on 340?
Sled is to oval ice race. Not much powder as long as sled leads pack.
Vader440
Re: Airbox versus Pods on 1979 Invader
« Reply #1 on: February 11, 2018, 03:10:46 PM »
I'm reading in my Assembly and Preparation manual and it says "never run the engine with the air silencer removed from the carburetor. Poor engine performance and engine damage will result". It goes on to say "properly position the plastic adapters on the carburetor prior to air silencer installation, to prevent breakage of the plastic econo jet fitting". It makes no mention of using other types of filters, but that doesn't mean it can't be done, I'm just not certain. Sorry I can't be more helpful. Perhaps someone more knowledgeable will chime in. Good luck!
72SSRS
« Reply #2 on: February 11, 2018, 03:30:43 PM »
The factory econojet carbs require factory air box for vacuum for carbs to work properly.  Sled wont run correctly without air box. That's why manual says. Could always put regular standard mikuni's on it and would not need air box ;)
rickbmac
« Reply #3 on: February 11, 2018, 04:06:25 PM »
340 does not utilize econojet
Teherr
« Reply #4 on: February 11, 2018, 06:39:35 PM »
I think you are right on the 340.  without econojet, you are good to run pods.  I do on all my kawi's without econojets.   Make sure you get good air flow under hood so you are not sucking hot air into engine.
440 Invaders
440 LTD Monohead
Liquifire
80' 4/6
Intruder Ice Oval Racer
74 El Tigre T7 Free Air
80 Polaris 440 TX
250 & 340 Enticers
