Author Topic: Single sno pro  (Read 63741 times)
Single sno pro
« on: September 20, 2018, 06:29:25 AM »
So this has been picking my brain for a while I started out with a Kawasaki single 292 fan engine milled off the fan shroud made some aluminum spacer plates and weld them onto the bottom case halfs as we speak I'm waiting back on my cylinder (added reed block) on a 550  interceptor I will be making a 2 piece head out of billet aluminum. Added features will be aluminum flywheel with electric start & a tuner pipe well lol mostly custom made I plan on putting this engine into my spare shark chassis as a 300 super mod leafer more to come oh if you're asking your self why this way the rules that I'm going off says it has to be a snowmobile engine 85' an older
« Last Edit: September 20, 2018, 08:10:30 AM by Interceptor398 »
750-h2
Re: Single sno pro
« Reply #1 on: September 20, 2018, 08:12:57 AM »
Wow!  I love what you are doing!!
Dandb7
Re: Single sno pro
« Reply #2 on: September 21, 2018, 05:10:55 AM »
Great mods...and beautiful sleds....Fast just standing still !!!
1979 Kawasaki Drifter 440
1989 Arctic Cat Pantera 440
Re: Single sno pro
« Reply #3 on: September 21, 2018, 06:21:49 AM »
Water cooled is being pumped with a electric water pump by Davis water pumps, the chassis is my custom hand built chassis including the hood, Conrad Seats built me this awesome seat, Wahlracing.com with miscellaneous parts like the radiator, Wild River Machine has made quite a few parts for me much appreciated more to come.
Re: Single sno pro
« Reply #4 on: October 10, 2018, 06:49:17 AM »
A little update the cylinder is in process within a month that should be ready to bolt on the shop said we can add in a few more ports if all this works out I might have to build a 550.
Re: Single sno pro
« Reply #5 on: November 05, 2018, 06:51:33 AM »
I've been working on the ignition need to machine a hub to fit the crankshaft. My gaskets & piston showed up waiting for some other parts to show up so I can start the fitting this altogether
Re: Single sno pro
« Reply #6 on: November 05, 2018, 11:39:34 AM »
This is very interesting!  I can't wait to hear how it turns out.  Do you plan on dynoing it?
Re: Single sno pro
« Reply #7 on: November 16, 2018, 06:35:18 AM »
Yeah I can get it dyno'd that costs $500 for 3 pulls dont think that's going to happen this year
Re: Single sno pro
« Reply #8 on: December 07, 2018, 06:16:45 AM »
An old friend just reminded me you can't rely on someone else been waiting for 3 months on my cylinder to come back at this speed I won't be running it this year or bringing it to Waconia I kind of wanted to race at Eagle River
Re: Single sno pro
« Reply #9 on: January 08, 2019, 06:23:14 AM »
Month 4 ? Still no cylinder so decided to look at the ignition a little closer instead of using Polaris ignition we found out that the Kawasaki 550sx flywheel bolts on including the keyway is the same, change of plans the other thing we decided to not use is electric start the  terminology that DanT says "kiss" ( keep it simple stupid ) is what we are going after more to come
Re: Single sno pro
« Reply #10 on: January 17, 2019, 12:04:37 PM »
Just curious, why reed valve instead of piston ported?
Re: Single sno pro
« Reply #11 on: January 19, 2019, 03:41:35 PM »
throttle response & more porting. For me it's just something I wanted to try.
The guy sent me a message stating he would love to build up a couple 440's with reed cylinder and compare it to the other brands that he's done already
Re: Single sno pro
« Reply #12 on: February 26, 2019, 09:21:43 AM »
Any updates on this?
Re: Single sno pro
« Reply #13 on: February 27, 2019, 11:14:23 AM »
No the guy modifying the cylinder still haven't heard nothing back
Re: Single sno pro
« Reply #14 on: November 09, 2019, 07:00:53 AM »
I just got my cylinder back I will get started back on this project soon
