Author Topic: ignition coil question  (Read 8033 times)
mrcsnow
« on: November 29, 2018, 12:14:27 PM »
Can a ignition coil of a newer 1982 Intruder fan replace a older unit with the 2 separate coil/ignition?
I did this and am having trouble getting my voltage regulator to work.
Thanks -Matt
Re: ignition coil question
« Reply #1 on: November 29, 2018, 03:43:50 PM »
What sled did you put it on?
mrcsnow
« Reply #2 on: November 30, 2018, 10:43:50 AM »
I have it in a 1982 John Deere Liquifire.  I switched motors from a 1982 Intruder engine to a 1979 Intruder engine.
« Reply #3 on: December 04, 2018, 04:24:47 PM »
Did the 82 Liquifire have a separate coil and CDI?  It should have had the combined CDI and coil.  I am not sure if the Intruder one would work.
There are other options.
« Reply #4 on: December 07, 2018, 06:19:49 AM »
If you take everything from one sled to the other it should work
