Author Topic: Thrush Washer Question  (Read 40910 times)
neworiginal
« on: April 12, 2019, 12:57:59 PM »
For the life of me I cannot find an expanded view of the 1980 340 crankshaft. Is my index finger pointing to the thrush washer? Are there only 2 or are all 4 thrush washers (2nd pic)? I am putting the C shim between it and the PTO crank bearing. Being safe and I'm second guessing. Thanks
« Last Edit: April 12, 2019, 01:00:07 PM by neworiginal »
1979 Invader 440, 1980 Invader 340, 1985 Yamaha XLV, 1980 Ski-Doo Citation SS
Re: Thrush Washer Question
« Reply #1 on: April 13, 2019, 09:04:10 AM »
Not sure if this helps?
neworiginal
« Reply #2 on: April 13, 2019, 12:44:31 PM »
Yes, thank you.
« Reply #3 on: April 13, 2019, 03:15:18 PM »
I just checked one of our cranks and see that the shim is between the mag side center bearing and the thrust washer.  I will try to post a photo.
« Reply #4 on: April 13, 2019, 03:21:37 PM »
Here is a photo  of the shim location.
neworiginal
« Reply #5 on: April 13, 2019, 03:56:00 PM »
Thanks Mark, I would have screwed that up and put it on the other side of the bearing. The pics in the manuals are not easy to follow.
