Author Topic: 1980 440 Drifter Carb troubleshooting  (Read 18000 times)
whitley1983
« on: February 26, 2020, 10:32:10 PM »
Hello, I just finished putting back together a 1980 440 Drifter, it fired right up but then was having trouble with it dying, had to keep the choke on the first position to keep it running. I took the whole carb apart and cleaned it really good then put it back in and started it up and it did the same thing. Then I adjusted the air screw and got it to where it was idling great, thought I fixed the problem but now it idles fine but when you give it gas it bogs down and will die. Any help would be great!!!!
-Jake
Re: 1980 440 Drifter Carb troubleshooting
« Reply #1 on: February 27, 2020, 07:42:31 AM »
Do you see any air bubbles in the fuel line?
« Reply #2 on: February 27, 2020, 08:07:36 AM »
When were the crank seals last changed?
whitley1983
« Reply #3 on: February 27, 2020, 01:16:57 PM »
I just finished completely rebuilding the entire engine, including new crank seals. I think I may have discovered what the problem is, at least why it started bogging down after I took the carb apart, I'm pretty sure I put the needle in wrong and it's not sliding up and down. Hopefully that's it, but yes I did notice some air bubbles in the primer line, didn't look at the main fuel line though.
whitley1983
« Reply #4 on: February 27, 2020, 02:14:23 PM »
That's all it was! Works great now. One other question though, the fuel to oil ratio I found in the manual I have says a ratio of 40:1 for normal operation, I mixed a few gallons with a slightly richer ratio because I couldn't find anywhere in there where it gave the ratio for break in, anyone know?
« Reply #5 on: February 28, 2020, 07:05:16 AM »
Yes, extra oil in the gas for the first 2 tanks full.
