Author Topic: Coolant drain plug O-ring need proper size  (Read 19981 times)
ArcticInvader
« on: April 28, 2021, 06:10:13 PM »
 Hi guys,
 On the front of the motor where the coolant pipe drain plug is , the O-ring part number 92055-3008 I looked in the parts manual it doesn’t give a size.. I have tried several different O-rings and I can’t seem to get it to seal..it pinches trying to tighten it up or it’s too small and it still leaks by ..I have a brand new pipe plug does anybody know the size of this O-ring ?
Thanks ArcticInvader
2010 Arctic Cat Z1 turbo
1996 ZRT  600
1996 ZRT 800
1995 Cougar 550
Projects : 3x 1980 LTD 4/6 all being restored
               2x 1978 Invader 440
                1x  1978 Invader 340
Re: Coolant drain plug O-ring need proper size
« Reply #1 on: April 29, 2021, 09:01:12 AM »
The one I have is .069 diameter  X .397 OD  X  .260 ID.     The O-ring is not what seals it, the tapered nose the 92066-3002 pipe plug seating in pipe 32032-3008 does that.  Maybe a piece of something is on that mating surface causing the leaking??
ArcticInvader
« Reply #2 on: April 29, 2021, 05:36:40 PM »
Thanks a lot Interceptor 398 , I appreciate the reply.
1996 ZRT  600
1996 ZRT 800
1995 Cougar 550
               2x 1978 Invader 440
                1x  1978 Invader 340
