Author Topic: Compression on a 1979 Kawasaki Intruder  (Read 15331 times)
jbenjamin
« on: October 02, 2026, 03:01:53 PM »
Hi All,
I purchased a 1979 Intruder last fall and I'm just getting started on this sled. I know very little about the sled, so I decided to look into what kind of condition the engine is in. I pulled the plugs out and they look brand new. I then went to pull the engine over and had liquid shoot out of both cylinders. There was so much that it shot what I think was oil (red) all over my ceiling in my garage (14ft). I just didn't expect that otherwise I would have covered the spark plug holes. I then covered the holes with a rag and continued to pull it over until most of the oil was gone. I hooked up a compression tester to each of the cylinders and both measured 150 psi. Is this normal, since the service manual states is should be 90 to 95 psi? If the service manual is correct this engine must have some type of modification to it. Just curious what some of you think about this?
Thank you for your response in advance.
JB
1978 Kawasaki 440 Intruder
3-1979 Kawasaki 440 Intruders
Re: Compression on a 1979 Kawasaki Intruder
« Reply #1 on: October 05, 2026, 10:33:49 AM »
150 is strong compression and would suggest the top end is fresh?
jbenjamin
« Reply #2 on: October 05, 2026, 03:59:46 PM »
Thanks Interceptor398, 150 sounds great but just wasn't sure if that was higher than normal. I just pulled the engine today and took off the heads to inspect the cylinder bore and it looks great, so I'm going to split the lower half and replace the seals since I have no idea when or if they were replaced.
Thanks again for your response.
JB
