Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
KawasakiTrax Community
Tech Information
General Help
Crank Gear removal on 1980 340 Invader
« previous
next »
Print
Pages: [
1
Author
Topic: Crank Gear removal on 1980 340 Invader (Read 12199 times)
AMXMETRO
Newbie
on:
January 08, 2013, 06:38:23 PM »
Here is what I need to know
Does the gear on the crank for the oil/water pump need to be heated to remove and reinstall like a flywheel ring gear
I am replacing the seals on the crank Thanks for the help
Logged
Sr. Member
Re: Crank Gear removal on 1980 340 Invader
Reply #1 on:
January 08, 2013, 06:43:03 PM »
you should be able to remove the gear with a bearing separater or a puller. to reinstall I set the gear on alamp with a 100 watt light bulb for a few minutes then it will drop on.
Logged
80 LTD 4/6 X2
Hero Member
Reply #2 on:
January 08, 2013, 08:01:00 PM »
Just a quick clarification, the gear comes off easily when the crank is out. It is a little trickier if you are not planning to remove the crank from the crankcase.
Logged
Intruders: 1978, 1979, 1981 Custom (Pink)
Invaders: 1980 440
Projects: 1981 Invader 440
AMXMETRO
Newbie
Reply #3 on:
January 09, 2013, 11:39:34 AM »
Thanks guys the gear pulled easy I just did not want to break anything important
Logged
Print
Pages: [
1
« previous
next »
Tech Information
General Help
