Author Topic: Crank Gear removal on 1980 340 Invader  (Read 12200 times)
AMXMETRO
« on: January 08, 2013, 06:38:23 PM »
Here is what I need to know
Does the gear on the crank for the oil/water pump need to be heated to remove and reinstall like a flywheel ring gear
I am  replacing the seals on the crank Thanks for the help
Re: Crank Gear removal on 1980 340 Invader
« Reply #1 on: January 08, 2013, 06:43:03 PM »
  you should be able to remove the gear with a bearing separater or a puller. to reinstall I set the gear on alamp with a  100 watt light bulb for a few minutes then it will drop on.
« Reply #2 on: January 08, 2013, 08:01:00 PM »
Just a quick clarification, the gear comes off easily when the crank is out.  It is a little trickier if you are not planning to remove the crank from the crankcase.
AMXMETRO
« Reply #3 on: January 09, 2013, 11:39:34 AM »
Thanks guys the gear pulled easy I just did not want to break anything important
