Author Topic: Clutching again  (Read 14724 times)
kwcrawler
Clutching again
« on: April 06, 2014, 10:12:50 PM »
I had 3 secondary clutches set up today to work with and 1 stock Primary and 1 P-85 primary.
 The 3 secondaries I believe had the same springs and then I set them up as Clutch 1: hole A hole 2; clutch 2: hole B hole 2; Clutch 3: hole C
  Clutch 1 :Hole A hole 2
  Clutch 2: hole B hole 2
  Clutch 3: Hole B hole2
It would only hit 30-40MPH; Then I noticed the primary was not coming up on the primary. Primary looks to have a lot of weight on it compared to the others I have for parts. Conclusion to much weight on primaries. I noticed a have 2 clutches one design and 1 clutch different from the other two. The one has two holes drilled on the top where the retaining bolt goes through.  Looking for clutch wear guides and the spilt washer retainer for primary.
What do you guys think?
Re: Clutching again
« Reply #1 on: April 07, 2014, 06:54:13 AM »
The primary with the 2 holes is an early one.  It will use different guide shoes but operates the same. If the primary is not opening I think it is froze up or the wrong belt maybe?
Re: Clutching again
« Reply #2 on: April 07, 2014, 08:12:46 AM »
78 models used the 2 hole primary with the notches on the other end.....you can use the long wear guides in them....how much weight on what ramps?
kwcrawler
Re: Clutching again
« Reply #3 on: April 07, 2014, 05:21:19 PM »
Is one primary better than the other? I was thinking about putting a p-85 clutch on it. Looks like I need to machine some more off the back of the P-85 clutch so it doesn't touch the engine mount.
Re: Clutching again
« Reply #4 on: April 08, 2014, 08:00:27 AM »
all the k brand clutches were basically the same, just some detail improvements over the years and different ramp/weight combos per model. remember, p85s take a wider belt than kaws
Re: Clutching again
« Reply #5 on: April 08, 2014, 08:24:30 AM »
What model sled are you working on?  Is it stock?  Modified?  What are you doing with it?  Trail sled?  Race sled?
kwcrawler
Re: Clutching again
« Reply #6 on: April 09, 2014, 12:30:19 AM »
I have two 79 Intruders one will be stock the other will be in the outlaw class.
Stock all stock with electric start
Outlaw class 440 fan: arctic cat 38MM flatslides,SPI pistons, porting and milling the jugs, wondering if i can get a set of reeds to work, 2 into 1 pipe 6 lbs, ski doo secondary, P-85 primary, Pro taper bars, tether swtch, and invader hood that has been modified, hydraulic brakes from a KTM, rear skid haven't decided yet.
