Author Topic: 1980 440 intruder pipes  (Read 12068 times)
gonzo
« on: April 13, 2014, 09:13:41 AM »
I have a 1980 invader with a intruder motor.I was wondering if I can put invader twin pipes from aaen on it.If so how much bigger would I have to go on the main jet.
Re: 1980 440 intruder pipes
« Reply #1 on: April 13, 2014, 11:35:39 AM »
I'm not sure I'd try Aaen pipes on an intruder motor...  The Aaen pipes are tuned to run around 9000 rpm.  It might be better to try some 4/6 LTD pipes/clutching and port the cylinders.
gonzo
« Reply #2 on: April 13, 2014, 01:56:53 PM »
Thanks for the info what do you think for clutching
« Reply #3 on: April 13, 2014, 06:31:06 PM »
I think I'd start with 4/6 clutching and adjust from there...
nitrofa340
« Reply #4 on: April 14, 2014, 01:15:52 AM »
 Back in 1983 I bought a used set of Aaen pipes, 38mm carbs, modified "J" ramps and  taller gearing for my Invader from an ad in the local newspaper. The guy I bought these items from had been using them on an Intruder,....not an Invader. He was speed/radar running his Intruder with these Invader parts. He showed me a 1st place trophy from a radar run,....94 mph. Keep in mind the standard distance back at that time for radar runs was 1320 ft,...not 1000 ft as it is today. Still very impressive regardless of the distance. I know,..I know,...those pipes/carbs/clutching arent supposed to work on an Intruder,...but I just wanted to share the story anyway. Dont shoot the messenger.
« Last Edit: April 14, 2014, 01:27:08 AM by nitrofa340 »
