Author Topic: Ratcheting/skipping track not sure why??  (Read 18475 times)
Tin-man
« on: January 05, 2014, 04:18:44 PM »
I was out on a ride in the fresh powder today. Sled runs great, and is very fast! I got into a large field where I was going full throttle on and off, traction is hard to come by when I hammer the throttle. The sled was a little sideways...and the track was spinning with not much traction. Then it happened.....the track was skipping or ratcheting on the drive cogs. This would only happen when I gave it full throttle.
I got home, and checked the track out. The track was very loose. I tightened it up, and ensured it was aligned. The cogs are looking good without wear. I had the chain case apart before this happened a couple of weeks ago to clean it up and change the fluid.
However, when I took the sled out for a test run after tightening the track, it still ratcheted.
I need some help and advice on what to look for. If you want pictures of anything let me know.
Thanks!
Re: Ratcheting/skipping track not sure why??
« Reply #1 on: January 05, 2014, 04:46:57 PM »
Can you take a photo of your drive cogs engaging the track?
« Reply #2 on: January 05, 2014, 05:05:31 PM »
 Dustin
 Take lots of pics of the suspension
Tin-man
« Reply #3 on: January 05, 2014, 05:06:13 PM »
Here is a video of the track, upon inspection, it is broken.  https://www.youtube.com/watch?v=P_mUQPfU1w0&feature=youtube_gdata_player
Thanks!
Tin-man
« Reply #4 on: January 05, 2014, 05:15:15 PM »
Thanks!
I have found that the suspension is broken in a couple of spots.  Out it comes.
« Reply #5 on: January 05, 2014, 05:17:52 PM »
It is always good to keep a spare suspension in stock for just such an emergency.
« Reply #6 on: January 05, 2014, 06:48:32 PM »
Broken mounting bracket will cause all sorts of problems including ratcheting track.
Habbeli
« Reply #7 on: January 06, 2014, 02:18:14 PM »
You might have the same problem as me, it skips in the chain case, though you think it's the lug
« Reply #8 on: January 07, 2014, 07:43:13 AM »
If it skips in the chain case you have a chain that is to long?  I have had the track skip but it was due to out of adjustment.
